What am i Missing?
Old Feb 16, 2004 | 05:39 PM
Meatikis's Avatar
Car: '86 Z-28
Engine: 350 bored .030 over
What am i Missing?
I recently put the the motor back in my car. when i try to start it, within a couple seconds the starter and solenoid start smoking. i believe its a ground problem because the wire from the batt. to the body fried after a couple of starts. the car is not computer controlled and has no electrical gauges. so i was thinking id list all the grounds i reconnected and maybe you could help me if i missed one. all the main grounds i hooked up are:
bellhousing to firewall
battery to block
battery to the body
msd to batt
dist to firewall
also the starter drive spins really slow when it engages.
any help would be appreciated.
Old Feb 16, 2004 | 08:46 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Are you using a stock or aftermarket battery cable?
Old Feb 17, 2004 | 11:28 AM
Meatikis's Avatar
Car: '86 Z-28
aftermarket - custom made
the small wire that goes to the frame on the batt cable fried after a couple of starts
Old Feb 17, 2004 | 02:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Try a different battery cable.
Old Feb 17, 2004 | 05:56 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
What did you do to the engine when you had it out? Did you do a rebuild? Is the engine too tight? Were there shims on the starter? Is the timing way too advanced? All these could cause a slow turning starter.
Old Feb 17, 2004 | 06:13 PM
Meatikis's Avatar
Car: '86 Z-28
no rebuild, i changed the oil pan gasket, rms, clutch, and a couple other things.
i put the shim that was there before i pulled the motor out.
im gonna try retarding the timing a little & get a new cable and see if that helps.
Old Feb 17, 2004 | 06:21 PM
TJQIROC's Avatar
Engine: 6.2 Gen V
I know there are ways to check the starter engagement clearances but I just don't remember. Maybe someone who has had this problem may respond. One shim might not be enough. With ignition key off, jump out the solenoid with a screwdriver (in neutral). Does it still crank real slow? Does it sound like grinding metal? You didn't happen to put a new flywheel on it?
Old Feb 18, 2004 | 12:20 AM
Meatikis's Avatar
Car: '86 Z-28
i found a couple of ground wires that were loose now it starts up perfect
Fireslash
Apr 11, 2016 06:43 PM
sammy52401
Nov 11, 2015 07:20 PM
BrianI
Oct 3, 2015 12:57 PM
Numbah-1
Oct 2, 2015 08:27 AM
lewandom
Oct 1, 2015 08:15 AM
