Slow blowing Heater
Old Feb 16, 2004 | 11:00 PM
snowman89's Avatar
Car: 1989 IROC-Z Camaro
Engine: 5.8L 355
Transmission: T-5 5-speed
Slow blowing Heater
My heater doesn't seem to work to its max....Like it doesn't blow that hard on high, and doesn't blow much at all on low. It doesn't seem like it gets hot enough either. I just figured I would ask. Thanks guys
Old Feb 16, 2004 | 11:17 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Are you referring to the air not coming out of the vents when you have it turned to heater. If so, all your heat is being diverted to the vents at the base of the center console. To get the max amount of heat from the upper vents, turn the selector lever to"VENT". It will make you nice and toasty.
Old Feb 17, 2004 | 09:14 AM
snowman89's Avatar
Engine: 5.8L 355
yeah thats what I mean. I turn it to Vent and it comes out slowly. It doesn't blow very hard, and doesn't get hot hot. it works, just not like I think it should. I don't really know.
Old Feb 17, 2004 | 10:19 AM
dcm01003's Avatar
Car: Black 89 Camaro RS w/t-tops
Engine: 2.8L (173ci) v6
whats your year and engine size??
Dave M.
Old Feb 17, 2004 | 11:37 AM
snowman89's Avatar
Engine: 5.8L 355
1989 350
Old Feb 17, 2004 | 12:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Just a quick question here Snowman89, does it do this only in the heater and vent mode or in all modes (A/C, bi-level, and such)? I have the troubleshooting chart.
Old Feb 18, 2004 | 09:09 AM
snowman89's Avatar
Engine: 5.8L 355
Yeah everything works, just slow. I'm beggining to think the fan motor is weak or something. Cuz the a/c doesn't really blow that hard either.
Old Feb 18, 2004 | 09:12 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey Snowman89,
Give a little while and I will send you some info on it by e-mail
Old Feb 18, 2004 | 02:09 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
Make sure the ground wire to the motor is clean/good connection.
Old Feb 18, 2004 | 05:54 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Snowman89,
I have some info to e-mail you but I need an e-mail address.
Old Feb 19, 2004 | 08:59 AM
snowman89's Avatar
Engine: 5.8L 355
Hflyr51@hotmail.com
Old Feb 19, 2004 | 11:08 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Snowman89,
I just tried to e-mail you that information and your mailbox just is not big enough. Do you have another address that I can send it to. If so, PM me with it so I can get this stuff to you.
bjpotter
Oct 4, 2015 07:48 PM
Luigytico09
Oct 1, 2015 08:46 AM
