Speedo needle?
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Speedo needle?
Just pulled my needle out and I have a rough idea at what MPH it was at but i'll probably be off by 5. I was just wondering if the 91 v8 gauge cluster's speedo needle resets by itself or do I have to try and install this one in the exact location? If so, can someone give me some tips? Thanks.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If it is like the 89's, then you have to try and install it in the exact location. I put a piece of tape on my speedo and marked the location with a pen when I had to take mine off. Seems to have worked, no tickets so far. But then again, I may have it on the high side.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
easiest way would be to hookup a laptop with a cable, or a scan tool.... drive a constant speed, and make the needle match what the screen says.
matter of fact, i drove into work today with the ALDL connected to the laptop.... i opened the digital dash and was comparing the two... mine is right no...
rs_z28_vert
Sep 30, 2015 09:47 PM
