Difference Between VATS and Passkey?
Old Mar 7, 2004 | 08:13 PM
PMGCamaro's Avatar
Car: 68 Camaro
Engine: Original 327 .040 over 89 TPI system
Transmission: M20
I am in the process of installing TPI into my 68 Camaro. The parts I am using are from an '89 Firebird, including the engine harness and dash harness. I know the VATS can be disabled by editing the PROM, but what about the Passkey module?
Is there a difference between the VATS and Passkey?
If I disable the VATS via the PROM, can I omit the passkey module from the installation?
Old Mar 8, 2004 | 01:31 AM
jonarotz's Avatar
Car: 91 Z28
I believe that they are the same thing. If it is removed from your Prom you should be able to get rid of the module without any ill effects. I have a 91 and I edited it out I just made sure that I also disabled the DTC code to keep the light from coming on.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
gta892000
Aug 11, 2019 11:16 AM
bbsr72
Sep 27, 2015 05:55 AM
383cam
Sep 9, 2015 06:01 AM
studebaker60
Sep 7, 2015 12:36 PM
