lock cylinder under dash!!
Old Mar 11, 2004 | 12:29 PM
grndmasnightmar
Guest
Posts: n/a
some fool put the vats lock cylinder under my dash wired into a new lock cylinder and my car itermittenly doesnt start. can i just put a resistor between the two yellow wires going to the vats lock cylinder under my dash and connect them?
Old Mar 11, 2004 | 04:31 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Let me see if I get this straight, correct me if I'm wrong here. You have a VATS lock cylinder wired in under the dash, and you have a lock cylinder in the steering column. Kind of sounds like my car, the previous owner had took a VATS lock cylinder and put an uncut key in it. He then connected it to the harness, rolled it up, wrapped it in about a roll of cheap electrical tape and crammed it up in the dash. He then put a regualr lock cylinder in the steering column because he was either too lazy or too stupid (possibly both) to correctly install it.
Old Mar 11, 2004 | 06:33 PM
grndmasnightmar
Guest
Posts: n/a
ditto
thats exactly the same but mine is wrapped in a shop towel. do u know how to bypass it? only the two yellow wires are connected to it now. can i just cut the lock cylinder off and splice in a potentiometer?
Old Mar 11, 2004 | 06:49 PM
3gc's Avatar
3gc
Car: Z28
Measure the resistance of the key in the vats lock cylinder under the dash and solder a resistor of the same value between the wires.
Old Mar 11, 2004 | 08:21 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
VATS info
Hey grndmasnightmar,
I just remembered, I sent you some info on this back in october. Is the connector still on both the cylinder and VATS control module wires? And I guess from your response that you have a standard lock cylinder in the steering column. You've just got to love some of these methods. Do you still have the info I sent you?
Old Mar 11, 2004 | 09:06 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
just a suggestion, instead of jerry rigging it, how bout since u have the cylinder already, install it the correct way?
Old Mar 12, 2004 | 07:04 AM
grndmasnightmar
Guest
Posts: n/a
well..
well trickster i have most of the info on how to do it thanks, and also i dont want to get involved with putting the vats cylinder back in. i think the easiest would just be to jump it with a resistor i already have 2 kill switches for security. and one more thing, should i just sotter together a few resistors to get a perfect resistance or will that be prone to failer during extreme weather?
thanks guys
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Stryker412
Sep 7, 2015 09:11 AM
SG91camaro
Sep 5, 2015 10:27 PM
andy74
Sep 3, 2015 08:41 AM
