Di-Electric Grease
Old Mar 12, 2004 | 01:29 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Di-Electric Grease
Anyone have recommendations for Di-Electric Grease. I got a small tube from Autozone but it seems too thin. I am looking for something like the OEM stuff that is thick and sticky.
thanks in advance,
phil
Old Mar 13, 2004 | 03:52 PM
BWW's Avatar
BWW
I am using this stuff called Harvey's silicone grease. it is like the OEM stuff. it comes in a little white plastic dish. I seem to remember getting it a home depot or Lowe's or something. You might want to give it a shot.
Old Mar 13, 2004 | 04:20 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Re: Di-Electric Grease
thanks in advance,
phil
Dielectric grease is not typically thick nor sticky. GM number is 12345579 for a 1oz. tube. Places like McMaster Carr have the industrial size tubes a lot cheaper. You are not confusing dielectric grease with heat sink compound? Heat sink compound is white and kind of tacky and is used to provide thermal transfer from an electrical component to it's heat dissapation mount. I use dielectric grease a lot and have not seen much difference from one brand to the other. Sometimes it has some runny crap out of the tube when first used, otherwise that's all I can think of.
Old Mar 15, 2004 | 11:37 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
All I know is the grease that is in my tail light bulb sockets, and turning signal light bulb sockets is yellow and thick and sticky. I assumed it was di-electric grease.
phil
Old Mar 16, 2004 | 04:37 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Know exactly what you are referring to Phil, I think it's just plain old garden variety grease. I have seen the dealer mechanics dab a wad of axle grease when replacing lamps in sockets. Silicone grease gets watery with heat as in the case of a lamp plus it's cost prohibitive in mass production. Just use a little wheel bearing grease in the socket, keep it off the bulb and you should be fine.
Old Apr 15, 2006 | 02:29 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
back TTT
can vasoline be used as dielectric grease...i went to home depot and radio shack today looking for some more dedicated dielectric grease and when i asked the workers there they looked at me like i asked for blinker fluid
needless to say neither had it...
Old Apr 15, 2006 | 10:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Try an auto parts store. I purchased at CarQuest.
JamesC
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
Numbah-1
Sep 12, 2015 08:57 PM
dyeager535
Aug 28, 2015 08:10 AM
