Acc fuse problem
Old Mar 12, 2004 | 06:44 PM
z2191's Avatar
Acc fuse problem
My acc. fuse keeps blowing. The pin switch in the pass door jamb was broke so the courtesy lights stayed on. I unplugged them until I was able to replace the pin switch. When I did and pluged the lights back, nothing happened. The acc fuse was blown and when I replaced it that one blew immediately. If anyone has any help I would really appriciate it.
Old Mar 12, 2004 | 07:54 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
I suggest that you take a look at the courtesy lights, perhaps when you reconnected them one of the leads became grounded on the lamp holder or the reflector - that's the only way I can see you blowing a fuse.
Unless someone popped a penny into your cigarette lighter in the meantime... That'll do it too!
Old Mar 13, 2004 | 12:48 AM
z2191's Avatar
No. The courtesy light is fine. I think the problem is somewhere between the pin switches, but I dont know exactly how they work. Ithought it was when the door is open the circuit is closed, thus switching the lights on. I will have to study the schematic more. thanks though
Old Mar 13, 2004 | 07:40 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Maybe part of the switch is grounding out on the body.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
