Need help low beams dont work
Old Apr 4, 2004 | 10:29 PM
CamaroFreak85's Avatar
Car: 1985 Camaro
Engine: 5.7, Vortec heads, Headers, TBI
Transmission: Built 700R4
Axle/Gears: 3.23 BW 9-Bolt Disc Brake
My low beams do not work when i turn on my lights but when i go to high beams they turn on but not as bright as the high beams but thats normal but they do not work at all when on low beams? I recently got silverstars for the low beams. I did some searches on here and found the headlight relay switch and i cant get it off i cant reach the last bolt on bracket isi there any easier way to this besides being gumby? i dropped the steering wheel already and that helped a little but im still haveing pronlems any help will be greatly appreciated thanks
Oh and any pics would be nice to help show me if anybody has any thanks
Old Apr 5, 2004 | 01:19 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The very first thing you should have done was check for voltage at the plug-in connector at the headlight. Then check the ground wires.
Old Apr 5, 2004 | 10:36 AM
Car: 1985 Camaro
I did check the voltage to the light on the tan wires if they are the same on the years but it was a complete circuit which should mean voltage too. i bought a new switch for the headlight and i had it off to the side and is still didnt fix it so its not the switch it self so its something in the wireing is there any inline fuses or something im missing and where are the grounds located at? any more information would be greatly appreciated thanks
Old Apr 5, 2004 | 11:17 AM
Car: 1985 Camaro
well i tried an old headlight i had in the lowbeam socket and it worked so has any one ever heard of just the low beam filement of the low beam buld going out and they are silverstars and they are not even 2 months old and it went out if any one has heard of that i would like to know i m gonna check the board for it but i think it is weird that both of them went out at the same time so if anyone knows it would nice thanks
jharrison5
Aug 19, 2015 05:53 PM
Fronzizzle
Aug 19, 2015 01:36 PM
jackhammer
Aug 15, 2015 10:04 PM
perZ
Aug 15, 2015 01:17 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
