Alternator Woes (kinda long)
Old Apr 8, 2004 | 01:56 PM
ljnowell's Avatar
Hey guys, Ive got quite a predicament here. OK here goes. I have a 1987 Camaro that used to have the 2.8 in it. When i still had the six, i put a nice stereo in that ate alternators fast. I had one custom built and no problems since. Heres the problem. I have an ACDelco alternator (small case) that was built, and I am currently switching my car to a V8. I decided to go with a Vbelt setup for $$$ reasons, and other reasons. The question I have is how will I get this alternator to work with the VBelt. It's no problem to change the pulley out, but I need a bracket set that will work. Anyone have any ideas? I cant really afford a new alternator, and I dont want to put in a POS and lose use of my stereo. Any help would be appreciated guys.
Old Apr 8, 2004 | 02:36 PM
racindaelky78's Avatar
Car: 1978 El Camino
Engine: 3??
Transmission: th350junk
http://www.jegs.com/cgi-bin/ncommerc...00&prmenbr=361
hope this helps
ok i use that 3 hole flat bracket for my lower with a spacer tube to mount the lower alternator bolt to the head and this bracket for my top mounted directly off the water pump.
Old Apr 8, 2004 | 03:12 PM
ljnowell's Avatar
And that works good with the small alternator, huh? Ill be damned. I have both the brackets in the top picture, but i need to find the one from the bottom picture. Im guessing I can find something similar in a JY, I hope.
Hotrodboba400
Dec 10, 2019 07:07 PM
Blue419
Sep 10, 2015 01:03 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
