pinout location help
Old Apr 20, 2004 | 09:28 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
I have unhooked my ac unit and have been running my cooling fan manually , but it's getting old. I have a few left over wires from the tpi swap and i figured i have a few left over since i am not running dual fans which the harness was set up for. The harness was off of an 89' iroc. I can't figure out which wire goes to the fan temp switch on the passengers side lower block. Looking at my old harness the wire looks like it had a ground wire spliced into the wire that went to the sensor, does that sound right? Anyone know what wire comes from the ecm to the sensor or does it run off from the relay?..... I looked on a wiring diagram but be damned if i can find the pinout number or the color of the wire.. Any help will be much appreciated...Thanks
Old Apr 21, 2004 | 10:43 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello David,
The wire that goes to that fan switch is a single wire and it is black. The knock sensor wire is white.
Old Apr 21, 2004 | 08:29 PM
Car: 92'Camaro RS
Engine: a loud one
That would be easy enough, but i don't have a black wire left over, ...I have a light gray wire (p/o D-11)....Dark Green wire (p/o B-8).... Green/White wire (p/o C-1).....and a light blue wire but i traced that and it splices off a wire to the heater controls. Ithink i lost the black wire because i am not using the dual fan harness. Any other ideas??
InfernalVortex
Apr 20, 2021 11:31 AM
Lbibb
May 5, 2016 12:00 AM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
