ECM Controlled Distributor
Old Apr 26, 2004 | 06:50 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Could someone give me a little insight as to how the ECM can control the advance on a late model (90-92) remote coil HEI.
I have a problem understanding how the advance can be controlled if the mechanicals inside the distributor are not moving (IE wieghts and vacuum)
I'm having current troubles getting my motor to run and need a little info to get a better grasp of what is happening there.
Thanks in Advance (I won't say retard!)
JP
Old Apr 26, 2004 | 06:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The ECM receives a reference pulse from the distributor, which tells it the position of the crankshaft. The ECM then tells the ignition module when to fire the coil.
Old Apr 26, 2004 | 08:20 PM
JP86SS's Avatar
Pulse advance?
That's what I figured, but I was trying to understand how you could fire the coil in advance of the reference pulse happening?
The other issue that I came up with is that if I set 6 BTDC mechanical baseline timing and my ECM can add a total of 41 degrees of advance (found in my bin file) this is a total of 47 degrees. (may or may not include the base timing figure)
There is only 45 degrees max between positions on the distributor (not including the overlap of the width of the rotor terminal which will actually increase the "usable" degree of rotation for firing each position).
Is the ECM using the previous pulse as the reference for the upcoming firing of the coil?
I'm really overthinking this but it has me asking the question.
JP
Old Apr 27, 2004 | 12:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Pulse advance?
Probably
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Gunsbee
Sep 7, 2015 07:10 PM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
