l98 alternator problem
Old Apr 29, 2004 | 01:37 PM
91z28 1le's Avatar
Car: 2000 grandprix gtp
Engine: s/c 3.8 v6
Transmission: auto
my question is put a brad new one on and it gets super hot. is there something wrong with the alternator or a ground problem.
steve
Old Apr 29, 2004 | 06:17 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What size and make alternator did you put on it?
Old Apr 30, 2004 | 05:24 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Does not matter really what output gen you put on, most likely its a 100 amp unit anyway. Yes, they get very hot. The CS 130 units had that major problem-heat. The rectifier pack generates a lot of heat which is transferred to the case since the case is used as the heat sink for the diodes. In fact, I have seen cases where the solder melts where the leads are attached from the stator to the diodes. Thats why the straight 130 had such a short life span both in the cars and with GM. The later "D" version addressed both the heat and low rpm output that the straight 130's suffered from.
lt500r55
Sep 1, 2021 01:30 PM
db057
Sep 4, 2015 07:57 AM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
