Gauge problem please help
Old May 2, 2004 | 09:34 AM
Incoming's Avatar
Car: 1986 Firebird T/A Streetracer
Engine: V8 350TPI
Transmission: Modified 700R4
My 1986 firebird T/A is having gauge problems all my gauges work but when I turn on my lights the gauges dont light up. So Im driving freestyle at night its not just the gauges that dont get power its also the lights for the airconditioner controls... What could be the problem?
Old May 18, 2004 | 01:55 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you checked the adjustment on the dimmer switch and the "TAIL" fuse and the "INST LPS" fuse for serviceability.
Old May 18, 2004 | 02:14 PM
Incoming's Avatar
Engine: V8 350TPI
The thing is the lights work about once a month... And then dont work the next time i turn my lights on... So im guessing its not a fuse. And i dont think its a short perhaps there is a stickin relay of some sort>?>?
Old May 18, 2004 | 03:04 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There is no relay in that circuit, just the fuses, the light switch, the dimmer **** switch, and the lights in the dash.
Old May 18, 2004 | 06:53 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
There's a second dimmer to the right of the steering column, tucked way inside the dash, that additionally operates the interior lights on a Firebird, at least. Its a bugger to find and you have to drop the column to see it. I believe it has a dark green and a black wire running to it. If it is defective or the wires melted or something (it doesn't have a heatsink for nothing!) none of the interior lights will work when you turn the headlights/parking lights on.
(I know this because I left the bugger unplugged when I reinstalled my dash and had no interior lighting until I plugged it back in)
Look for the item in the picture in this post:
https://www.thirdgen.org/techbb2/sho...hreadid=240097
It's the second thread from the bottom.
Ghettobird52
Jul 5, 2024 11:18 PM
rocn7roc
Sep 21, 2021 02:16 PM
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
justin57
Aug 20, 2015 07:05 PM
