Blinker holds the light instead of blinking
Old May 3, 2004 | 10:23 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
The turn signals on my 82 do not blink when they are supposed to. All it does is turn on the light and keep it on until I move the lever back to the center. The indicator lights show the turn signals are keeping the light on also.
It started to do this a few days ago.
My dad said my flashed which is under or in the dash needs to be replaced and I could replace it myself.
Now I have to manually make the turn signals blink. arg
The worst part of the day is on the way home I got pulled by a civic.
Old May 3, 2004 | 11:04 PM
AM Racer's Avatar
If it's the same for both the left and right side, then replace the flasher.
If it's only on one side, then check for burned out bulbs.
Old May 4, 2004 | 12:20 AM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
It's on both sides.
Around how much does a flasher cost?
Old May 4, 2004 | 03:08 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I need to replace mine on the formula, sometimes the pass side doesn't blink, the indicator blinks but not the lights. I have to tap the underside of the dash to get it to work again.
What does it look like?
Old May 4, 2004 | 06:57 PM
AM Racer's Avatar
If the indicator blinks without the outside, you have other wiring problems not related to the flasher.
It can't choose which bulbs to operate.
Old May 4, 2004 | 07:02 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Firebirds, like camaros, have the flasher relay (yellow arrow)clipped (green) to a dash support (aqua, also is what amps. the obnoxious sound).
It's just in front of the 'convenience center' (orange) and mounts opposite, of shown in the pic, side of the brace.
Attached Thumbnails Blinker holds the light instead of blinking-dcp_0012.jpg
Old May 4, 2004 | 09:45 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I just replaced the flasher, and everything works fine. I picked it up for $6.12 at a dealership.
All I had to do was unplug the old one in the black box(orange line) and plug the new one in.
I got an AC Delco part.
Gm part # 10041073
Application: 1982 Firebird
Old May 4, 2004 | 09:57 PM
AM Racer's Avatar
Hey, learn something every day. I never paid enough attention to them also using a relay.
Old Jun 30, 2004 | 07:58 PM
decibeta's Avatar
Car: 1982 T/A
that pic is worth a billion words
Old Jul 11, 2004 | 10:36 PM
Driberif85's Avatar
Car: 85 Firebird
Engine: 2.8
Than you for the pic. Kept me from putting a bullet in my car
Wade787b
Sep 29, 2015 01:15 PM
Jk_Under
Sep 2, 2015 10:59 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
zeitghaist
Aug 18, 2015 07:33 AM
Omega
Aug 10, 2015 12:46 PM
