a stupid question, but will save time
Old May 4, 2004 | 02:01 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
hey everyone,
i finally got around to wiring up my fan switch for manual fan control (tapping into green/white wire to toggle and then from switch to ground). Before i tap into the green/ white wire is my question: do i really have to disconnect my battery? the reason i want to know this is because i have an alarm on my car and when i disconect the neg wire off the battery it screams bloody murder and i don't feel like setting it off. so pretty much i'm asking is it ok as long as the key's not in the ignition and the ignition isn't on?
-GTAman
Old May 4, 2004 | 02:07 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
for safety reasons you generally always want to disconnect the battery when working on your electrical system.. but theres no power going to that relay with the ignition off, you'll be fine
Old May 4, 2004 | 02:11 PM
GTAman's Avatar
yeah i thought so too, but that was just what i wanted to hear. thanks man :hail:
-GTAman
Old May 4, 2004 | 02:15 PM
GTAman's Avatar
sorry but i forgot to ask one more question: where is the best place to ground the from the toggle switch? i just read the FAQ on grounding things and i'm a bit paranoid O_o
-GTAman
Old May 4, 2004 | 08:34 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
I grounded my manual fan switch to the driver's side headlight ground it is working just fine for me.
Old May 4, 2004 | 08:46 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
you need to ground from the toggle switch inside teh car or in the engine bay ??
if it is in the car, you can do it pretty much anywhere, dont let hte tech articles scare you. as long as you have a clean connection you will be alset. if the switch is near the radio you can even tap it into the ground for the radio.
Old May 4, 2004 | 10:08 PM
GTAman's Avatar
everything went pretty smooth today. the way i ran the wires is, in the ps fender, there some hollow room so i ran the wire from the engine bay through the hollow space into the inside of the car. as for the ground, i found a pre-existing hole near the fender so i sanded off the paint and ground it there. it's crazy tho, i tapped into the aux fan relad and both fans come one at the same time. is this supposed to happen?
-GTAman
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
gta power
Aug 13, 2015 06:15 AM
