HYD head lights
Old May 7, 2004 | 07:56 PM
hot69z's Avatar
Car: 1982 Z/28 H.O.
Engine: 355
Transmission: t-5
HYD head lights
Ok im pretty fluent when it comes to wiring i have 1 question about using these lights. According to the specs of the headlights they draw more Amps than the standard sealed beams The factory harness doesn't have very thick wires 14 gauge off the top of my head. Do i dare run the lights using the factory harness and risk a fire?? or do i make a new light harness that runs closer to the lights using a relay?
Old May 9, 2004 | 12:53 AM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
id do it the relay route, better safe than sorry, spend a few dollars on some good wire and relays, or use the stock wiring and wonder everytime u use your headlights is the wiring gonna start on fire
Old May 9, 2004 | 02:00 AM
hot69z's Avatar
Car: 1982 Z/28 H.O.
Engine: 355
Transmission: t-5
ok now my next question is how do I wire up to the light switch and bypass the factory from the switch...
Has anyone done this on the board I would be interested in finding out how they did it
Old May 9, 2004 | 02:07 AM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
you dont have to replace your light switch to use the hid lights, what u do is use the stock wiring to trigger the relays which the hid lights run off of, stock switch
Old May 9, 2004 | 02:20 AM
hot69z's Avatar
Car: 1982 Z/28 H.O.
Engine: 355
Transmission: t-5
what im asking is which wires do i use from the switch as trigger wires for standard and which ones for high beam? I have never wired headlights (other than using factory harness)
Old May 9, 2004 | 04:57 PM
Flamingo's Avatar
Car: 89 GTA
Engine: 5.7 TPI
On the tech page is an article discussing how to do this. I did it on my 86 IROC and it made a big difference, but I havent done it on my 89 GTA yet, as the sealed beams arent all that bad on it. https://www.thirdgen.org/newdesign/t...tupgrade.shtml
ThirdGen.Org
Jae992
Aug 27, 2015 09:07 AM
Dialed_In
Aug 20, 2015 01:45 PM
Omega
Aug 10, 2015 12:46 PM
