Speedometer Broken
Old May 12, 2004 | 06:27 PM
csun91RS's Avatar
Car: 1991 Camaro Rally Sport
Engine: 305 TBI
Speedometer Broken
I have bought a 91 Rally Sport with 305TBI and since I purchased it the speedometer has not worked. I replaced the entire gauge cluster with a new cluster that I knew worked. Where should I start to find the problem with my speedometer?
Old May 12, 2004 | 11:29 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Well if the gauge fuse is good, I would start looking at the Vehicle Speed Sensor (VSS).
Old May 13, 2004 | 12:34 AM
midlifeman's Avatar
Car: 1986 Trans Am
Engine: Mighty LG4
I've developed problems with my speedo also. Changed the gauge cluster, helped some, but the needle still bounces, especially under acceleration. Where is the VSS and what can a guy do to check it?
Thanks.
Old May 13, 2004 | 12:40 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If your car has it, it will be mounted on the transmission and the buffer will be mounted under the dash on the passenger side near the ECM. Are you getting a code 24 (VSS circuit)
Old May 13, 2004 | 01:04 AM
midlifeman's Avatar
Car: 1986 Trans Am
Engine: Mighty LG4
Sorry Trickster, I'm way too new at this to know anything about codes. I don't have a clue how to check for one. All I know is the speedo worked fine when I bought the car last year, then one day it just started jumping around after the first few minutes of driving. The new cluster almost fixed it, seems fine when I'm decelerating, but still jumps around a bit especially under heavy acceleration.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
sheachopper
Jul 31, 2019 11:27 AM
no green
Jan 9, 2016 09:22 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
