purple and yellow wires behind fuse panel
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
I have a empty connector with a thick purple and yellow wire under my drivers side dash hanging behind the fuse panel. and i dont know what they are.
i checked my other 88 ta,and it does'nt have them wires. does anyone know what they are for???
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Did your car have a manual transmission in it at one time. If so, there would be a connector in that area that would go to the clutch start switch.
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Both of my Firebirds - 86 and 89 - have provisions for the neutral/clutch safety switch for both the manual and automatic transmissions. Both cars were T5-equipped, and both had the plugin connector inside the console to hook up to an automatic shifter. Weird.
Car: 88gta
Engine: 357
is there a way to find out. i dont think it was ever a 5 speed car and then why doesnt the other one have it
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No, his only has two wires to it and is hanging behind the fuse panel. The connector in that picture is under the center console and would be the Park/Neutral switch connector in a car with an automatic transmission.
Ghettobird52
Jul 5, 2024 11:18 PM
