Iac Setting
Old May 24, 2004 | 03:15 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
Iac Setting
want to know if the IAC is suppose 2 be set electronically. if so wahat are the settings?
Old May 24, 2004 | 04:12 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is adjusted manually as shown in this picture.
Old May 24, 2004 | 07:53 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
does the gaset have 2 be sealed with sealant? and what can i mesure it with?
Old May 24, 2004 | 08:34 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No, the gasket isn't sealed and you would measure the distance with a small ruler. 28MM is about 1 1/8" or you can measure with the metric side of the ruler.
Old May 25, 2004 | 03:09 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
thank u man. ill hit back
Old May 25, 2004 | 03:41 PM
DJXero's Avatar
Car: 1992 Camaro Z28
Is there anything special that is needed to be done to a new IAC before installing it?
Old May 25, 2004 | 03:44 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Just make sure it is set to the proper lenght as shown in the picture.
specialized
Jun 18, 2022 09:26 AM
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
86IROC112
Aug 21, 2015 12:39 PM
perZ
Aug 15, 2015 01:17 PM
