Dang thing wont Start
Old May 29, 2004 | 04:07 PM
gscm75's Avatar
Car: 02 chev. Avalanche, 1989 IROCZ28
Transmission: auto
I have an 89 IROZ 5.7 350 with a Viper 300+ alarm and after we replaced the starter cycloid the car won’t start. no crank no click no nothing when you turn the key. We’ve taken a multi-meter to it and the cycloid is fine and the starters good as we got it going after manually making the connection. It is behaving like the alarms kill switch is engaged, any suggestions?
Old May 29, 2004 | 08:20 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello gscm75,
Welcome to the board. When you changed the starter solenoid, did you put all the wires back where they were. The purple wire with the small terminal lug goes on the small post marked "S". It is the final link in the ignition circuit. Also check all your connections at the solenoid and battery.
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
86White_T/A305
Aug 17, 2015 12:16 AM
