why wont my hazards work
Old May 31, 2004 | 10:50 AM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
the button doesnt do anything wether i pull the outer part out of push the center in, it doesnt do jack.
heres a pic
Old May 31, 2004 | 10:51 AM
Borsty's Avatar
Car: 89 Trans am
another pic
one more
Old May 31, 2004 | 11:18 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The flasher relay in the convenience center is probably shot. The convenience center is located under the dash by the drivers right knee. The relay will be a round unit.
Old May 31, 2004 | 11:29 AM
Borsty's Avatar
Car: 89 Trans am
but shouldnt the hazard button still do something pyshically?
like move and click into place or something?
Old May 31, 2004 | 11:39 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Sorry, I mis-understood your post. When you push the center button in, it will remain pushed in until you reset it by pulling the outter ring outwards. From looking at the first picture, it appears that you can pull the outter ring out. If the center button doesn't push in, then you will have to pull the steering wheel off and find the problem inside the column
Old May 31, 2004 | 12:09 PM
Borsty's Avatar
Car: 89 Trans am
Could i take off the screw in the center? woudl that do anything?
Old May 31, 2004 | 01:54 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Sure you can take that screw out the center and other than holding the button to the switch on the turn signal switch assembly inside the steering column it does nothing. I don't know how much pressure you are putting on that button, but on mine it takes more than a casual push to operate it.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
