wierd headlight problem
Old Jun 1, 2004 | 10:23 PM
86transamws6's Avatar
Car: 88 IROC - 86 Trans Am
Engine: L98 Carbed - 350 Carbed and boosted
Transmission: auto - T5
When I turn on the headlights in low beam, the outter lights go on. Then when I put on the high beams, the outer light get brighter, and the inner lights never go on...what's wrong?
Old Jun 1, 2004 | 10:35 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Does your high beam indicator come on? If it doesn't, I would check the ground for it since that is also the ground for the high beams.
Old Jun 1, 2004 | 10:39 PM
yes the indicator light comes on
Old Jun 1, 2004 | 10:48 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Then I would check the light green wire that comes off the headlights to connector A2 on the driverside firewall connector. That light green wire also goes to the fog light relay.
Old Jun 2, 2004 | 12:20 PM
k ill try that
Old Jun 2, 2004 | 01:49 PM
still no luck, any more ideas? I need to get it inspected tomorrow and idk if they will pass me if the inner lights dont come on
Old Jun 2, 2004 | 02:23 PM
AlbertaFbody's Avatar
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
i had a similar problem but mine were simply burnt out. as for yours getting brighter that almost sounds like the HB circuit is tied into your low beams had any one ever messed around with your lights or did they work before
Old Jun 2, 2004 | 05:36 PM
Ummm...the outer lights ARE supposed to get brighter, thats why they have two filaments. I just replaced the high beam switch for the one from my parts car, and still no luck. I also tried using a bulb from the parts car with no results either...So its not the bulbs, not the switch, not the indicator...Im running out of solutions here
Old Jun 2, 2004 | 05:54 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here is a wiring schematic for your headlights and a troubleshooting hint chart. NOTE Item #2 which is circled.
Old Jun 2, 2004 | 05:55 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Old Jun 2, 2004 | 10:25 PM
Thanks for the diagram man, but I still can't figure it out. When I turn the brights on, the outer lights' bright filament goes on...its just the inner lights that never go on. It appears from the diagram that both lights on either side use the same light green wire and the same grounds...
Old Jun 2, 2004 | 10:54 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Actually the left high beam has a seperate ground. Have you used a multimeter to check the light green wires for continuity.
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
