Engine ground strap
Old Jun 3, 2004 | 01:32 PM
BWW's Avatar
BWW
Engine ground strap
I have just put my battery in the trunk and it is grounded in the trunk. Now I am wondering-
Where is the best place to put the engine ground strap?
Old Jun 3, 2004 | 02:08 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello BWW,
Not being sarcastic here, but the best place to put the engine ground strap is on the engine. BTW, what are you doing about the fusible links to the starter solenoid
Old Jun 3, 2004 | 06:41 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Run the engine ground to the front subframe rail. Grind/sand the paint off where you're going to connect the wire so you get a good connection. Also, ground the battery to the rear subframe rail in the same fashion. You need the thicker metal of the subframe because the sheetmetal floorpan doesn't conduct very well. Ask me how I know.
Also, you can just leave the fusible links where they are....the battery cable still has to go to the starter.
Old Jun 4, 2004 | 02:53 PM
BWW's Avatar
BWW
indeed i do know the engine ground strap goes on the engine but i was wonderin if the was a place on the engine that would be best. every thing is good to go but the strap
thanks
Old Jun 8, 2004 | 12:18 AM
Tyler-88's Avatar
what i did was ground the battery to the rear seat belt bolts in the back seats and left the factory ground strap that goes from the back of the block to the frame and than i added another ground that goes from the accesory brackts to the strut tower brace
BRoss99
Aug 10, 2025 05:08 PM
E Rod
Aug 28, 2015 05:17 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
