seem 2 come out w/no problems
Old Jun 7, 2004 | 05:58 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
why am i able 2 take my key out of the ignition w/out no problems while the car is on? i can drive w/out the key in the ign at anytime. is this somthing i should be worried about? been like this 4 over 1 1/2 year. just wondering was there a problem before or is there going 2 b a prob.
Old Jun 7, 2004 | 11:09 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
your lock cylinder is worn out, you may be able to have a new key cut & it not do that for a while, or a new key may not even be able to work the lock cylinder at all. a new key may also cause the lock cylinder to to stop working completely. sooner or later you will have to replace the lock cylinder, if it hasn't already started, it will get harder & harder to get the key to work in it, or it will get to where you don't need the key to turn the lock cylinder. when to replace it is up to you. if it were mine,.... i would change it soon.
Old Jun 8, 2004 | 07:42 AM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
good lookin out
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
