One wire left, and missing one, help!!!
Old Jun 9, 2004 | 05:59 PM
AlabamaThunder's Avatar
Car: 1986 IROC-Z, 1990 RS
Engine: 383 Stroker TPI, 350 About To Go In
Transmission: 700R4 W/ Shift Kit And Stall, 700R4 W/ Shift Kit
Okay, I've got one wire and i don't know where it goes..Besides maybe the starter.
The hot batt. cable goes to the big post along with 2 other fused wires (orange)
Then the little purple wire going to the "S" post.
But I have another orange wire the same size of the puple, does it go on that other post to the left of the purple wire?
Then on the coil, it has two places for wires to plug in, I can only find ONE to fit it. which side guys? and should i have another one?
Thanks...I wanna get this baby started up today.
-Jensen
Old Jun 9, 2004 | 10:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It will go on the big post with the battery cable, there are two connectors for the ignition coil, a black one and a gray one and both have pink and white wires, The wires in the black connector go to the ignition module in the distributor and the wires in the gray connector go to the ignition and tachometer inside the car.
Old Jun 10, 2004 | 06:45 AM
Like I said, this orange wire is the same size as the purple, it will not fit. I've already got two or three orange ones running to the big post with battery cable.
On the coil, I found the grey connecter which I see will only fit to the left male. I've yet to find the other connecter on the harness. But maybe I'm just over looking it.
Thanks Trickster
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Cleotiz
Jan 6, 2018 08:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Bert87
Aug 23, 2015 03:50 PM
