Speedo
Car: 91 Firebird
Engine: 191ci 6cyl
Speedo
So I wasn't sure which subject to put this under and figured I'd take a shot here. My speedometer sticks real bad. Usually I get to 30 before it moves, sometimes it'll move quicker, sometimes it'll be perfectly fine. This gonna be a cable problem or a gauge problem? I bought a cable but haven't gotten under my car yet to try and change it. Figured I'd find out now since I'm gonna be doing a shift kit and vette servo.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Sounds like your speedometer is sticking due to dirt and 'dried up' lube. You'll need some non-detergent oil to re-lube the bushings in the speedo.
Since you have a 91.... there is no cable, the speedo is electric. You need to take the speedo cable back to where you got it and slap the salesperson in the face with it for even giving it to you.
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
My speedo on my camaro would not work when the car was cold. Then it would shoot up about 20 miles into my drive. I replaced the VSS yesturday and it works perfect now.
real simple 1 bolt holds it in.
First go under your car and on the driver side of the transmission right before the drive shaft you will see a round thing with a wire connector pluged into it that is your VSS
write down the numbers off it so you can get the correct one. It cost me 40 dolalrs from GMPARTSDIRECT.com
You take the screw out and connector off twist the VSS out put the gear on the new VSS slide it in screw it back in plug the connector in and your good to go. Its a 10mm bolt that holds it in.
Oh you will have some transmission fluid come out when you take it out but its not allot
Car: 91 Firebird
Engine: 191ci 6cyl
Yea of course when I buy the good tranny fluid cause I'm changing the filter I have all this crap to do were fluid will come out. Vette servo, shift kit, VSS.
Elephantismo
Feb 13, 2019 12:51 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
