Quick question on wiring LED
Old Jun 12, 2004 | 02:00 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
I need an LED to go in this base (the bulb on the right):
So I was looking at one of the white LEDS on this page:
http://www.superbrightleds.com/leds/w5_specs.htm
I think it would fit in the base, but would that one single LED light work with 12 volts? Or is there something else involved.
Old Jun 12, 2004 | 05:03 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Hooking a single LED up to 12 volts will blow it all to hell. Quickly.
Using a single white LED, you would need to use a 560 ohm resistor in series with either lead. A red one would require 680 ohms.
Just be aware that those LED's have a relativley narrow beam to them; this particular one is 45° which is large for an LED. You may end up needing several to flood the area with light; this would require a different resistor value, which you can figure out by using this calculator http://www.hioutput.com/tech/circuits/resistance.html
Use a figure of 14.7 for automotive circuits, as that is close to what is in the system when charging.
Old Jun 12, 2004 | 06:22 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Thanks. Its still new to me. Not sure what I am doing when I have to do it manually.
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
