Tach Flicker, help fix
Old Jun 15, 2004 | 02:38 PM
91CamaroDude's Avatar
Car: 91 Camaro RS, BEAST
Engine: 305 TBI
Just recently my tach has started to flicker while the motor is reving up. at idle it's fine, but sometimes while driving it'll flicker up and down by 1000 rpm. Where should I look to fix this problem? or what might i need to replace?
Old Jun 15, 2004 | 02:49 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
I would start by checking the tach connector where it plugs into the Distributor.
Old Jun 15, 2004 | 04:23 PM
Engine: 305 TBI
I removed and checked every wire going into my distributer and the tach still flickers at high rpms. any more ideas???
Old Jun 15, 2004 | 04:29 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It doesn't connect into the distributor on his car. It comes straight off the white wire of the gray connector on his ignition coil and goes straight to the tachometer on the instrument cluster. There is a single wire connector near the distributor that is a diagnostic connector for the tachometer. It is a part of the wire going to the instrument panel. The picture you have listed above is correct, try moving the wires away from the sparkplug wires a little. On some cars there is a noise filter in the circuit for that problem.
Old Jun 15, 2004 | 05:22 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
I sorry I forgot that his car runs the small cap External Coil.
Dumb me lol
Old Jun 15, 2004 | 06:39 PM
Engine: 305 TBI
well, rechecked everything again, and tucked the tach wire down away from the sparkplug wires and it still flickers.
it ONLY happens at higher rpms and when im on the gas, (downshifting doesn't flicker)
If all connections are good and there are noise filters involved, maybe one of them went bad that, or maybe the insulation on the plug wires has gone bad causing interference. what do you guys think?
thanks
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
86maro_252
Oct 10, 2015 06:52 PM
BWilcox
Sep 20, 2015 12:19 PM
TrevinE
Sep 14, 2015 03:20 PM
