firebird headlight question
Old Jun 20, 2004 | 10:39 PM
nick62087's Avatar
hey everyone, i have a question about how firebird headlights work...
what controls the motor going up/down, and what starts and stops teh motor when it reaches the desired point?
i don't own a firebird, or i'd just look at the wiring
however, im workin on a project for either my camaro or my caddy...
i acquired a 3rd gen firebird headlight, i believe its out of an 87, and im converting it into a retractable liscence plate frame. i took out the headlight, the plastic piece, and some other useless crap, so basically its just stripped down to two hinged moving parts. I duct taped a liscence plate to it and tried it out. they way i have it set up, if it were bolted under a car, the liscence plate would be showing. When the headlight folds, the liscence plate rotates so that its not visible to anyone behind the vehicle. anyway, when i touch the wires onto a battery the motor moves.
How would i properly set up the wiring?
I'm an electrician, so i kno how it all works, but i just need to know exactly what i might need. i assume i'f need either limit switches or timed relays. Eventually, i'd like to wire it up to the button on my cadillac keyfob that opens the gas door (pointless)
thanks!
Old Jun 21, 2004 | 06:19 AM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
i believe the motor stops from resistance, on the bird theres no switch it just shuts off when the rods hit the stops
Old Jun 21, 2004 | 01:04 PM
nick62087's Avatar
yea, my first hypothesis is that it stopped with a change in resistance or an increase in current draw, but my issue is, i want to use momentary pushbuttons with holding contacts, and i need something to cut the power when it reaches the desired position
-thanks!
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
