shift light
Old Jun 22, 2004 | 08:00 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
shift light
i just hooked up a proform shift light 67005c and i does not light up after 3 grand, when i set the dial at 3 grand on the light, it lights up at about 2400. if i set it on 4-5 grand it still won't light up after 3 grand, do you think i should send it back, or could i have wired it wrong....i grounded it on my driver right seat mount, ran a power wire from my battery to the power wire on the light, and connected the last wire to the white wire on the coil. what do yall think... thanks.
Old Jun 22, 2004 | 11:47 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I'd personally send it back.. sounds defective IMO.
Guessing you direct wired as stated to test it's working, it should function w/o a problem.
Old Jun 23, 2004 | 01:13 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
i started reading the intructions once again and it stated that i could be defected if you didn't connect a certain diode to the wire leading to the coil, so im gonna go to radio shack and try it out, if it doesn't fix it im sending it back
LittleFranks
Sep 17, 2015 12:22 PM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
