NO POWER at HEADLIGHT MOTORS
Old Jul 1, 2004 | 11:48 AM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
Transmission: 700r4 race built
Axle/Gears: 4.10 posi
I have an 89 firebird formula, I cant figure out why im not getting power at the headlight motors. I changed the headlight module and still no power, the motors definetly work (I hot wired them). Each headlight motor has a 2 wire plug. IS THERE ANY FUSES THAT GO TO THE MOTORS. any ideas will greatly appreciated.
Old Jul 1, 2004 | 01:02 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Check your 'tail' fuse and also check for power on the 2 red wires at the module. They should both have constant power... helpful drawing
Old Jul 1, 2004 | 01:04 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
There are two fusible links, blue in color, inside the wiring loom about 6 or 8 inches from the module.
Old Jul 5, 2004 | 04:20 PM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
I have power going threw the module and the fuseable links are good but still no power at the motors. Is there any groundsthat i check.
Old Jul 8, 2004 | 09:59 PM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
anyone
Old Jul 8, 2004 | 10:29 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes, there is a ground on the actuator relays. They are at pin "C" on connector C1 of each one. There is also two fusible links in the circuit with one going to pin "A" of connector C1 on each actuator relay. They should have red/white wires.
Old Jul 10, 2004 | 01:47 PM
Morley's Avatar
Check both wires going to the motor to ground, you should be getting 12V (more or less) on each wire. The module switches ground from one wire to the other depending on if up or down is being selected. If you have 12V on both wires, then remove your headlight switch and clean the contacts on it and the harness end and try again.
This is based on the 91 firebird headlight wiring, not sure when it changed from the individual relays to the module, but if it has the control module on the firewall it should work the same.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
86White_T/A305
Aug 17, 2015 12:16 AM
stalkier
Aug 13, 2015 12:59 PM
