Brain Dead Help
Old Jul 10, 2004 | 06:13 PM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Brain Dead Help
Hey guy's I'm totally confused or or the section of my brain that holds this information that I know that I know how to do it has up and ran away or most likely those particular brains cells are dead! ha!
Here is the problem.
I have been working on the engine wiring in my '91 Iroc with a L98 motor & 700R4, I've been doing a little at a time I thought I had it all finished but I seem to be at a dead end trying to figure out how my injector wires go. I know that 1, 3, 5, & 7 injectors wires connect together and then connect to the ecm hole number C12 and the 2, 4, 6, & 8 wires come together and connect to the ecm hole C11. Where does the 2nd wire from each injector side go to? are these wires the ones that need to connect to the fuel inj fuse 1 & fuel injector fuse 2 wire? Or do they connect to the D side of the connector ( I believe connector "D6 & D7" ) which are supposed to be to Ground. Dis I answer myself or do I have it all *** backwards? Help would really be appreciated as I am working on it as we speak. ( Well I stopped long enough to write this S.O.S.. I'll pop back in every 10 minutes or so to see if anyone of you fellow third genners got my S.O.S.
Thank you!
CALIROCZ28
Old Jul 10, 2004 | 07:03 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello CALIROCZ28,
Your question has been answered in one of your other threads, there is no reason to continue opening threads in each forum hoping that someone will respond. Trust me, you will get a response to your question. It only creates confusion by having someone post numerous threads on the same problem in each forum.
Old Jul 11, 2004 | 12:20 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Point taken, sorry about that. It won't happen again.
CALIROCZ28
skinny z
Carburetors
Sep 29, 2015 11:25 PM
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
Jonas Earl
Sep 27, 2015 07:39 AM
Johnoooooo
Sep 22, 2015 08:55 AM
