removing ECM
Old Jul 15, 2004 | 03:43 AM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
removing ECM
hey guys, did a search, didn't find anythign right away however I searched at 1 30am in the morning, so i thought i'd ask. I have a 91 V6 RS. taking out motor and putting in a carbed 406. by the sounds of it, all gauges will still work. the special coded key thing might be an issue, and I have to ground out my TCC? also my electric speedo needs a special device to read foram a mechanical speedo tranny.
but anywho, I took off the panel under where the passanger feet go. and noticed two silver boxes there. so i'm taking one of them is the ECM/ which one is which? and what is the other one? do I cut, or disconect? rewire what? easiest to take off dash?
thanks a bunch
cheers
blake
Old Jul 15, 2004 | 09:21 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: removing ECM
thanks a bunch
cheers
blake
I believe the bigger box is the ecm and has more connectors. I think the smaller one is the ESC. Does the smaller one piggy back the big one?
Old Jul 15, 2004 | 09:44 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
no, they are about 5 inches apart, smaller one is closer to the middle of the car
Old Jul 16, 2004 | 01:52 PM
I believe they are what I said they are. The larger one for ecm. I am not familiar with 90-92 models. I cant tell you whether to disconnect the smaller one or not. I disconnected mine tho.
Old Jul 17, 2004 | 08:32 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
hey took some pix of what i think is the ECM, also you can see a picture of my finger pointing, and thas roughly to the other metal box which is behind the dash, whats that? leave it?
also another pic of me holding a empty female connection, possibly for the floor lights, for when the doors are opened? because I know my car doesn't have those, if it is, if I put the proper light and male connector in, should it work? or would the it not be rigged up and fused up for use?
cheers
blake
Old Jul 17, 2004 | 09:08 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If it has one connector in the side of it, it is the Diagnostic Energy Reserve Module (DERM). If it has two connectors in the top of it, it is the Vehicle Speed Sensor (VSS) buffer box.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stryker412
Sep 7, 2015 09:11 AM
willyjoejr
Sep 3, 2015 09:26 AM
RyanJB
Sep 2, 2015 01:27 PM
