Autometer Oil Pressure gauge, sending unit questions
Old Jul 18, 2004 | 12:56 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I was wondering if the sending unit on the autometer gauges output range is the same as stock, so that I can just tap into the factory gauge wire. How did you guys install yours? Thanks.
Old Jul 19, 2004 | 07:34 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
you didnt say but im guessing you still have the computer. if you do you have to find alternate locations to put the aftermarket senders. i would not suggest using the stock senders in either case as the gauges were probably calibrated to the aftermarket senders.
Old Jul 19, 2004 | 07:56 PM
Rellim88's Avatar
I installed a complete set of autometer gauges a couple of years ago. I replaced the sender that is mounted on the back of the block behind the intake manifold (by the distributor) with the autometer sender. Its been a few years but if i remember correctly there is a seperate sender for the computer mounted by the oil filter. This is the sender that cuts the fuel off if oil pressure drops too low.
Old Jul 20, 2004 | 08:04 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
My auto meter sender is too big to fit behind the intake?? I am going to tee off the sender/switch above the oil filter for my gauge.
Old Jul 28, 2004 | 11:20 AM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
On my stock setup, there was this big bell shaped sender, and your autometer is bigger than that?? Why not get a brass extension tube, and plug your sender into that?
I'm using a mechanical Autometer oil pressure gauge, so it's a little different.
Just my $.02
Old Jul 28, 2004 | 11:29 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The gauge senders have nothing to do with the computer.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
