acc fuse problem
Old Jul 18, 2004 | 05:33 PM
ryguy85's Avatar
Car: 1985 Z28
acc fuse problem
Hey i was wondering if anyone had ideas to help me. all the wires for my radio was cut by the previous owner. so whenever i try to put a fuse in the acc spot it just sparks at me so i take it away so the fuse does not blow. this happens even when ignition is off and key is out. im trying to get the fuse to stop popping becasue i need my horn to work to pass safety inspection. all help would be greatly appreciated thanks
Old Jul 18, 2004 | 07:01 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Drop the fuse panel down and remove all the extraneous garbage that has been attached to the ACC fuse connector and check it for any loose wire strands that might be causing a short up there.
Old Jul 18, 2004 | 07:17 PM
ryguy85's Avatar
Car: 1985 Z28
just to make sure with you. would having all the radio wires cut make any difference to this problem.
Old Jul 18, 2004 | 07:29 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What year, model is your car? The reason the ACC fuse will continue to pop with the key in or out is because it has 12 volt power to it at all times. You said that the previous owner cut all the wires for the radio. If none of the wire ends were wrapped in electrical tape, the power lead for the radio might be grounding out causing the fuse to blow.
Old Jul 18, 2004 | 07:46 PM
ryguy85's Avatar
Car: 1985 Z28
its an 85 z28. so to make sure that its not grounding out i should wrap all the ends up in electrical tape. thanks for the tip i never thought about that before. your a great help trickster keep up the good work. thanks for all yoru help
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
