alternator wire question
Old Jul 20, 2004 | 10:15 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have a brown wire that went from the Alternator up towards the coolant fan relay, then splits off. One goes to the relay and the other inside. I hooked the wire that went inside up to a switched 12 volt (to turn the Alternator on?). I can follow the wire on diagrams that goes into a coolant fan relay, but then where does it go, ignition switched?
Old Jul 20, 2004 | 10:42 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The tan/white (brown) wire that comes off the alternator does split off. One wire goes to pin "D" of the coolant fan relay and the other wire goes to the "FP-FAN" fuse on the fuse panel which is hot in the run position.
Old Jul 21, 2004 | 10:17 AM
Tibo's Avatar
Car: 1991 Z28 Vert
So would this explain why my AC and vent/heater are not functioning?
Old Jul 21, 2004 | 10:37 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you are referring to the blower motor for the AC/Heater, it is on a seperate circuit and gets its power from the HTR-A/C fuse for the A/C control head and a fusible link at the starter solenoid provides power for the blower motor.
eightsixseven
Dec 16, 2024 01:50 PM
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
