what is wrong...
Old Jul 20, 2004 | 11:25 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
what is wrong...
Engine will idle but if you give it any gas the engine back fires and stumbles. Both my tach and my oil pressure gauge just stopped working. What is the problem?
Old Jul 20, 2004 | 11:43 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
what have you messed with lately on the car
Old Jul 20, 2004 | 11:48 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
i was going to attempt to do a tranny swap but as far as i got was getting the drive shaft out, unbolted a couple things that hold the tail shaft on, and then i went after the converter bolts but couldnt get them off. So the only thing i did that would have possibly had an effect on the engine is i didnt have the engine in the exact same spot as when i had started working on it because i had spun the converter around a bit hence turning over the engine. However i put the car back together, took it out, drove it for about 2 hours on and off, was running great, get within 2 minutes of my house and it starts stumbling and backfiring. Now it wont even make it past the end of the street.
Old Jul 21, 2004 | 10:56 AM
sockfootball22's Avatar
Car: 84 z28
it might be your fuel filter or your pump
Old Jul 21, 2004 | 06:44 PM
THEGENERAL's Avatar
have you got under the car to make sure nothing came unpluged ?
Dante93GTZ
South East Region
Apr 23, 2010 01:27 PM
trucker
Brakes
Mar 31, 2010 08:25 PM
Rich92 RS
Mar 25, 2010 05:03 PM
Justin Horne
Car Audio
43
May 3, 2005 09:29 AM
Z-BOSS
Apr 27, 2001 10:43 PM
