more acc fuse problems
Car: 1985 Z28
alright ive brought out the books and looked through here many times. ive hooked up a light to the fuse and its light with doors open and off when the doors are closed but if i open up the door the fuse pops again. what am i suppose to be looking for ive looked through all the acc fuse stuff checked everything. its driving me nuts could it be the horn relay. i dont have a rear hatch release or cargo light not that i dont think. ive just got this car and just got into messing with it. anyone with pictures of compants or general help. PLEASE speak up i need all the ideas i can get.
Thanks big time
Ryan
Thanks big time
Ryan
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Ryan, did you look at all the information that I gave you in your last post..
https://www.thirdgen.org/techbb2/sho...hreadid=251517
P.S. to make things simpler, continue with the thread that you started instead of continuing to open new threads.
Car: 1985 Z28
sorry about all the new threads ill just keep it to this one. yea i have that book and checked out all those pages. three or four times. im just wondering if im looking for a wire thats cut or touching metal. and is that red wire really making these fuse pops because thats the only thing i can see wrong or out of place. and its a swapped in 350 so would there be any link coming off of the starter or not?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes, there are fusible links coming off the starter solenoid as pictured. That red wire is supposed to be on the ACC fuse. These pictures are out of the 85 camaro GM service manual. Now did you check the wires that you said were cut for the radio to see if they were shorting out. Look to see if there is something above the fuse panel making contact somewhere shorting things out.
Car: 1985 Z28
alright ill check the wire coming off of the starter and route it into the acc fuse. i wrapped off all of the wires for the radio just like you said and i think that might have taken care of my radio fuse from blowing which is good. could the red wire be the reason for this fuse to keep popping
