battery drain
Old Jul 27, 2004 | 01:51 AM
mastertrixter's Avatar
Car: 82 z-28
Engine: L69
Transmission: muncie T-10
battery drain
okay, first i hooked up an amplifier for my stereo. I thought there may have been a bad internal circut in the amp. But anyways, it drained my battery, beyond the point of saving. Then i hooked up my fog lights. Drained the battery again. I followed all wiring instructions, hooking the positive leads to the positive battery terminal and grounding to wherever i found a suitable ground. Does anyone have any idea what could be causing this?????
Second, i would like to add an msd ignition to my setup but i don't know what will work. I have a HEI distributor with vaccum advance. Which systems will work for my car????
any help is greatly appreciated
Thanks,
CODY
Old Jul 28, 2004 | 10:06 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Your amp may have shorted which could cause a draw. The only way to check for sure is to use an ammeter. As far as the fog lights go you need a switch somewhere. The way you describe the hookup, the light should always be on.
Old Aug 2, 2004 | 12:02 AM
Car: 82 z-28
Engine: L69
i have an inline switch for the fog lights, and i used an amneter to check for the draw and there isn't any when the car is off? yet the battery still dies. but when i disconnect them from the battery it doesn't die, even after sitting for a few days
Old Aug 2, 2004 | 12:10 AM
MasterEvilAce's Avatar
make sure you're using the ammeter properly.. start at the highest setting for AMPS, then drop the scale down one at a time, and see if the needle moves
Old Aug 2, 2004 | 11:56 PM
Car: 82 z-28
Engine: L69
i used it properly. I just can't seem to figure it out, unless i had a bad ground somewhere on both the amp and fog lights. oh well, i've decided to take them both out anyways.
I still would like to know what ignition system people reccomend for me though. Engine info is in signature
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
drumstixer
Sep 29, 2015 03:02 PM
raymondandretti
Sep 27, 2015 06:43 PM
