115+ cut out
Old Jul 30, 2004 | 02:18 PM
camaroboy1984's Avatar
Car: 91 camaro RS, soon a 2005 ZO6
Engine: 305 V8 tbi
Transmission: auto
115+ cut out
i found this on here
https://www.thirdgen.org/newdesign/tech/unlimited.shtml
and tried it, and got nothing, no check engine soon light, nothin, and yes i spliced the right wire, no i didnt take it above 115 to find out that it didnt work, i was doing about 35 for a minute and no check engine light, and the speedo didnt drop when i flipped the switch; i got a 91 RS; im wonderin if the wiring diagram is for an older year, does any one got any ideas?????????
Old Jul 30, 2004 | 11:23 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
If you wire it at the ecm your speedo should still work. No signal from the vss will not necessarily throw a code immediatly seeing as no signal is normal for a condition where the rear wheels are not spinning. You can try driving it around longer to see if you can get it to throw a code.
Old Aug 3, 2004 | 03:27 PM
Engine: 305 V8 tbi
Transmission: auto
thanks
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
