Wiring troubles
Old Aug 5, 2004 | 12:24 AM
Louwww's Avatar
Car: 88 Firebird Formula
Engine: L98, changing to T1
Transmission: 700R4 to 4L60E
Wiring troubles
i'm working on an lt1 swap into my 88 formula, and the wiring is giving me a headache. anyone know a performance shop in central NJ that could help me out??
Old Aug 8, 2004 | 06:34 PM
Vader's Avatar
Are you using the original '165 ECM and a retrofit distributor, or the LT1 PCM? Is the LT1, what year PCM? There were only about four different PCMs. Fun, eh?
Old Aug 8, 2004 | 06:40 PM
Louwww's Avatar
95 lt1 with its full harness and ECU...
Old Aug 8, 2004 | 06:50 PM
Vader's Avatar
I trust you got the LT1 MAF as well.
What are the problems? The entire PCM and harness needs to be installed into the ThirdGen, and most of the connectors are specific to the LT1. As long as the LT1 harness is intact, there shouldn't be a real problem. You may have a fun time integrating the ignition switch and VATS, but if you have a schematic for both the original L98 and the LT1, it should be easy enough, if not very time consuming.
Remember, solder everything instead of using crimp splices, or you'll have headaches later.
Old Aug 8, 2004 | 07:28 PM
Louwww's Avatar
yes i have the maf too.
the problem i'm having is the integration of the ignition working with both the lt1 and the car's chassis wiring (lights, accessories, etc.). i also happen to be very bad at wiring and schematics, so i was looking to go somewhere else and save myself the trouble.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
djmarch
Aug 19, 2015 12:07 PM
