Need help tracking down Fan Switch problem.
Old Aug 18, 2004 | 07:39 AM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
Hi-
My problem is that my electric cooling fan isn't turning on. I have let it it warm up to about 240 and no results. The radiator fan switch in the car is new. If I unplug the fan switch connector and clip the contact on the connector to the neg batt terminal, the fan goes on no problem so I know the fan works. But the temperature switch doesn't seem to be doing anything.
Since it's a new switch, I didn't think it would be that. Could it be the relay? Or would the fan not work at all if the relay was shot?
Should I just try replacing the switch again?
If you need the info:
86 camaro sport coupe LG4
Thanks.
-Matt
Old Aug 18, 2004 | 08:42 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Try replacing the fan relay first since you have had the fan working by jumpering the connector. Just a thought!!!!!!!!
Old Aug 19, 2004 | 12:21 AM
305PhoenixAm's Avatar
Car: 85 Trans Am
Engine: 383 TPI (Yes, TPI. Not for long though)
Haha, I replied to this on accident. [edit], yup. And if the relay doesn't do it make sure the place didn't give you a coolant temperature sendor instead of a fan switch..for some reason that happens sometimes.
Old Aug 19, 2004 | 08:14 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I think that he would find the difference in the two when he tried to connect it.
Old Aug 19, 2004 | 09:49 AM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
Thanks for the replies.
Yeah, the one in there is definitely a fan switch. Got the connector that looks like the one on the knock sensor. I'll try the relay and if that doesn't work, i'll try replacing the switch again.
Thanks again.
-Matt
Old Aug 22, 2004 | 07:44 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
If the fan runs when grounding the wire it eliminates the relay as being the problem. The switch grounds the relay.
Old Aug 22, 2004 | 02:11 PM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
Would a coolant leak cause the fan not to go on(switch not to ground)? I think I've got a pretty serious leak from the intake gaskets.
Old Aug 23, 2004 | 06:41 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Sure would.
Old Aug 25, 2004 | 01:14 PM
BadNewsCamaro's Avatar
Car: 87 camaro
Engine: 305 carb.
believe it or not i had the exact same problem, if i grounded the wire the fan would turn on but if i let it heat up........nothin. So after alot of fooling i came to find out it was just the connecter on the end of the wire was bad. I put a new one on and let it heat up and TADA! the fan kicked in.
Old Aug 25, 2004 | 02:17 PM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
Hmmm...
I'll give that a try. Where can I get that connector? Should it be something readily available locally or somewhere on the web?
Thanks for the reply.
-Matt
eightsixseven
Dec 16, 2024 01:50 PM
GTAman
Mar 15, 2019 11:40 AM
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
TA8487
Aug 16, 2015 12:21 PM
