horn
Old Aug 18, 2004 | 09:02 AM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
horn
can someone show me the whole wiring set up from the horn to the actual button in the steering wheel, i can't get mine to work, and i have no idea where to trace the wires from... any help?
Old Aug 18, 2004 | 08:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes, here is a schematic of the horn system for your car. You will notice a little circular item in the schematic labeled "slip ring. This a circular piece of plastic with a metal ring on the backside of it and fits on the steering wheel hub and makes contact with the turn signal cam follower. It has a little tower on it that the wire from the horn button fits in. Have you checked the horn relay in the convenience center to see if it is good?
Old Aug 18, 2004 | 09:04 PM
Dingley's Avatar
Engine: LG4 305
where is the relay located?
Old Aug 18, 2004 | 09:41 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
By your right knee near the ALDL, here is a picture of it. The horn relay will be a little square unit in it and not the item that is circuled in red.
Veaceonee
Sep 29, 2016 08:15 PM
Fox118
Sep 1, 2015 04:07 PM
tc7761
Aug 30, 2015 09:45 AM
Stauf
Aug 24, 2015 08:31 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
