Are these battery specs ok?
Old Aug 20, 2004 | 01:56 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
While my car was in the garage a couple of months back I had them replace the battery as it was dead. I'm just wanting to check they replaced it with one that is powerful enough.
The battery says:
Capacity (Ah) 70 Amps
CCA (Aen) 640 Amps
Robert
Old Aug 21, 2004 | 05:21 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
640 amps should be plenty to turn over your starter.
Old Aug 23, 2004 | 06:53 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Stock AC Delco battery is a 75 amp/hr batt with 650 CCA and 830 CA. You should be fine.
Old Aug 23, 2004 | 03:03 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Thanks guys.
meeklay812
Oct 1, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
raymondandretti
Sep 27, 2015 06:43 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
