headlight motors for the older third gens, get ones 87-up ?
Old Aug 21, 2004 | 03:27 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
87-up are the motor assemblies ot get for the 82's right ?
which ones had two wire and which ones were three wire? when did they change, and how to convert ?
fiero ones work too ?
years of the better ones?
any other models ?
years ?
need any other parts from donor car other than the motors and harnes plugs ?
need ot grab any of the wire length from the donor ?
how to bench/yard test them ?
thanks
Old Aug 21, 2004 | 06:31 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
87-92 used a two-wire motor, previous ones were 3-wire.
If you're gonna swap in a set of later motors, you'll also need to swap in the entire relay harness as the relay setup was totally different between the two styles; it's probably just as easy to swap the entire lighting harness under the hood, from the bulkhead connector to the sockets.
Old Aug 22, 2004 | 11:00 AM
rclenhardt's Avatar
Car: 1982 Firebird SE
Engine: 350 V8 4bbl (H)
Transmission: TH 350 Automatic
If you have an 82' Firebird, I would try to get the correct 82-84 motors. They are very good and rarely go bad.
They can be bought off ebay or new ones can also be found.
Old Oct 25, 2004 | 09:49 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
huh ? thats the first time i have ever heard that the early ones are good,
i always hear about how its better to get later ones
the ones i took off my 82 t/a are munched inside, looks like plastic gears smashed to bits in them
if early ones are good then are later ones really bad/worse then ??
now im lost
hum
(scratches his head)
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Aug 19, 2015 01:36 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
stalkier
Aug 13, 2015 12:59 PM
