left rear speaker
Old Aug 29, 2004 | 05:35 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
left rear speaker
Left rear speaker is out. somtimes it comes on for a very short while. its a good speaker cause it works fine on the right side. what is this?
Old Aug 29, 2004 | 05:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you mean that you swap the speaker from the left side of the car to the right side and it works fine. Then you have a problem with the wiring on the left side of the car or you have a problem with the left rear channel of the radio.
Old Aug 29, 2004 | 05:50 PM
badseed71386's Avatar
Car: 1984 camaro
Engine: ethiopian gerbil, those things can really run, when you put food infront of it.
Transmission: whatever makes it go
bad wires
check your wires do they look old and corroded if so then replace them you might have to look beyond the hook ups like inside panels and behind the radio.
Old Aug 29, 2004 | 05:53 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
the dude who had the car before me had a little sound system in it, but when he took it out it did not effect the speakers. this problem has been going on for about 2 months now.
1992 Trans Am
May 10, 2023 07:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
89lsc
Aug 14, 2015 04:58 PM
