MAF problems.
Old Sep 1, 2004 | 04:34 PM
89IROCZTPI's Avatar
Car: 1989 IROCZ
Engine: Rebuilt 350 TPI
MAF problems.
I originally posted this question in the tech/general engine forums, but after a few replies, it makes me think my problem(s) may be electrical. My symptoms are thus: If the MAF is plugged in, the engine wont stay running, it stalls out. If I unplugg the MAF, it idles fine, albiet a bit rough. Ive read through my haynes manual and the only thing I could see was a burn off relay and a 20a in line fuse, and the ECM fuse under the dash(which was the only one I could actually find, and its ok) Looking for some help as to isolate my problem further, and to see if I need to get a new MAF sensor or not, thanks!
Old Sep 1, 2004 | 07:38 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You also have a MAF Sensor power relay sitting next to the burn-off relay. Have you checked the connector on the MAF sensor? Are you getting any trouble codes?
Old Sep 1, 2004 | 08:25 PM
89IROCZTPI's Avatar
Car: 1989 IROCZ
This is pretty much the area im lost at, the Haynes manual sucks as far as telling/showing me where the relays are, or what I should be looking for as far as possible problems. The plug itself looks fine, ill recheck the sensor also. Thanks Trickster.
Old Sep 1, 2004 | 08:34 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here is a picture of the relays, the MAF relays are the ones to the right of the fuel pump relay on the driver side firewall.
Old Sep 1, 2004 | 08:40 PM
89IROCZTPI's Avatar
Car: 1989 IROCZ
very nice Trickster thanks!! I did check the middle one, the plug itself looked fine, should I unbolt them from the wall and check them? Also, is there any way you could tell me what readings I could take at the plug going into the sensor itself?
Old Sep 1, 2004 | 08:50 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Sure, here is a chart for the code 33 that should help you.
Old Sep 1, 2004 | 08:51 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
part 2
Old Sep 1, 2004 | 08:55 PM
89IROCZTPI's Avatar
Car: 1989 IROCZ
you are the MAN my friend!!! Once again you come through Now how can I just get my hands on one of the handy books you have? Thanks again!!
Old Sep 1, 2004 | 09:32 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Well you can either go through Helm Inc. and pay $146.00 or take the cheaper route and go on E-bay and bid on one there. One just went yesterday for $46.00 plus shipping. I think there are about 2 or 3 more on there right now.
Old Sep 1, 2004 | 10:29 PM
89IROCZTPI's Avatar
Car: 1989 IROCZ
sounds like a 46 bucks well spent if ya ask me, thanks for the heads up, think ill head over there now
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
