Electrical a\c problem
Old Sep 1, 2004 | 09:00 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Here goes.........Air was working fine. Then one day the fan(Blower) wouldn't come on (18 years old). Replaced blower motor. Same problem. Replaced Relay (i can hear it click and the voltage at the fan is 13.5) Same problem. (Oh, by the way, the compressor still cycles.) I can hot-wire the fan to the battery and it works, the relay clicks and when it is engaged, the power plugs to the fan show 13.5 volts, but it won't run!!!!!!!!!!WTF!!!!!!!!!!!!!!!!!! I've replaced everything (fan and relay, and the resistor coils are good)Just as an added bonus, sometimes it works. Sometimes it will just quit while running (blower) Most of the time it won't work. Sounds like a short, but no evidence of one. HELP!!!! It's hot in Texas! Bad blower motor???????????
Old Sep 1, 2004 | 09:56 PM
NoTransistors's Avatar
Car: '83 Firebird S/E
Engine: The Chevy 305. with carburator
Transmission: 700R-4
Have you looked at the single-conductor inline connector under the radio? Usually melts. Might be your problem.
Old Sep 2, 2004 | 08:47 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
You mean the 13.5 shows against good ground or on the pins in the connector? Could easily be a bad ground. It shows good voltage unless you put load on the wire.
Old Sep 2, 2004 | 04:26 PM
Car: 1985 IROC Z-28
Engine: 355
Axle/Gears: 3:73
Found the problem. It was a ground problem. Thanks, guys. OK, I'll let everyone know what an idiot I am. The blower fan has it's own ground to the intake (at least that's where it was hooked from the factory). During the intake repair, it "got lost". Found it today while poking around. It had worked its way behind the block. Hooked it up, and all is well.
Old Sep 2, 2004 | 10:48 PM
BigBadLou's Avatar
Engine: TPI
You are welcome. That's what we're here for, my friend.
toones
Jan 6, 2016 06:00 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
