Electrical Connection On Radiator Tank...??
Car: 1992 Camaro RS Convertible & 1983 P
Engine: 305 TBI & 305 4 BBL & 4.7 liter
Transmission: Auto & Auto & 5 Speed Manual
Goofy Question:
Radiator tank, passenger side, about half way down from fill cap, is an electrical (spade) type connection on the tank. There is nothing connected to it.
1) What is it for?
2) Should there be something connected to it? (I looked and did not see any loose wires dandling about)
3) Where did it go, if it was supposed to be connected to something?
Thanks!
shipfitter_sjd
1) What is it for?
Thanks!
shipfitter_sjd
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally used as a coolant low level sensor on some cars. On mine which is a 1989 Iroc, there is a brass plug in that location. Nothing to worry about if it isn't connected to anything.
Thank you!
That is kind of what I suspected. I have never seen that light before on my dash, so.....................?
Thanks!!
shipfitter_sjd
Thanks!!
shipfitter_sjd
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
Re: Electrical Connection On Radiator Tank...??
ressurecting this one, how do you disable this sensor so that the light does not come on? i have the digital dash so removing the bulb is not do able. i think it just has to be grounded but not sure.
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
anyone? all i need to know is if grounding the sensor wire will eliminate the low coolant wanring from coming up
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
If I remember right that has to have less than 50,000 ohms to ground for the light to stay off.At more than 50,000 ohms the light will come on.
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
i should think a well done ground would have less then 50 thousand, thanks
Hotrodboba400
Dec 10, 2019 07:07 PM
Bohemian
Aug 15, 2017 05:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
