choke light. hehehe
Old Sep 8, 2004 | 09:48 PM
cyipher's Avatar
Car: 1984 Pontiac Trans Am
Engine: 305 SBC
Transmission: Automatic
choke light. hehehe
Well let me start with telling you i already used the search function... now with that out of the way. My choke light is on ive tried 2 altenators, and 2 choke relays with no change. when i disconnect the choke from the connector i read 14.3v and the choke light gos out, when i connect the connector on pops the choke light and my voltage drops down in the 1.5-2v range. i have tried another choke and it has the same affect. where do i start with this problem?
Old Sep 8, 2004 | 10:37 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you looked at the wiring? Do you have the dash with the gages or indicators?
Old Sep 8, 2004 | 10:53 PM
cyipher's Avatar
Engine: 305 SBC
i have the dash with the choke light and volt gauge
Old Sep 8, 2004 | 11:16 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Does it look something like this? Might want to check the grounds and the oil pressure sending unit.
Old Sep 8, 2004 | 11:17 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Old Sep 8, 2004 | 11:34 PM
cyipher's Avatar
Engine: 305 SBC
Old Sep 8, 2004 | 11:38 PM
cyipher's Avatar
Engine: 305 SBC
i was looking at previous posts and saw this diagram, is it the same for vin g engine? or do you have a diagram similar to this for a vin g engine. also this is for a 84 firebird.
Old Sep 9, 2004 | 12:22 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The information that I posted is out of the 1984 firebird GM service manual. The drawing that you have listed there is not out of the 84 firebird or 84 camaro manual. To my knowledge there was not a VIN G in the 84 firebirds, there was a VIN 7. Also according to your previous post you had the dash with the gages in it. That schematic you have posted is for dashs without gages only. Here is the charging schematic for the V6 & V8 engines in the 84 firebirds. The second schematic here is the schematic for the choke heater on the V6 & V8 engines in the 84 firebirds with gages in the dash.
Old Sep 9, 2004 | 12:23 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2.
Old Sep 9, 2004 | 01:04 AM
cyipher's Avatar
Engine: 305 SBC
what is the point of the resistence wire?
Old Sep 9, 2004 | 08:24 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
This!!!!!!!!!
Old Sep 9, 2004 | 05:51 PM
cyipher's Avatar
Engine: 305 SBC
ok found the problem, bad connection at fuse panel.
Old Sep 9, 2004 | 09:26 PM
cyipher's Avatar
Engine: 305 SBC
OK Trickster... YOU ARE THE MASTER OF THE UNIVERSE!!! :hail: :hail: :hail: Thought it was the fuse, But 5 fuses later it wasnt, looks like its going to be the oil pressure sender thats at fault. Disconnected it put in a new fuse and wala it worked with out poping the fuse. I'm going to put in a new sender tomorrow and i will post my results.
FormulasOnly
Jul 23, 2018 08:47 AM
Grant2k
Apr 4, 2016 08:21 AM
HoosierinWA
Oct 7, 2015 10:15 AM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
